what's up,..
I asked this before but wasnt too clear....Is it
possible to start encoding(to VCD) with TMPEGenc pause
then continue from the same point...without having to
start from the beginning ?...by that I mean..Can i start
encoding .shut down my computer..turn it back on and
then continue from where i left off?..or do i have to
start everything over again...?.....Thanks
It would be nice if you could pause (but not shut down your computer) just to check email or do other stuff. For those with less powerful computers, that would be a bonus I think.
Note, you can do this with FlaskMPEG with the Panasonic MPEG encoder plugin. Flask let's you use "pause" and "resume" and this doesn't affect the resultant file.
I don't know if there is a way if you can use FlaskMPEG and TMPGEnc via frameserving and do this though.
Regards.
Michael Tam
w: Morsels of Evidence -
AntnyMD - Just go to the Options menu of TMPGEnc and under task priority - set it to normal if in front, and idle if in background.
THen, when you want to encode full-tilt, move TMPGEnc to the foreground. When you want to do other stuff, just do it, TMPGEnc will then only use idle cycles. Works fine. -
If you hit the STOP button during processing it will prompt you "Abort Encoding" YES or NO. Leave this message box open and it's "paused". When you're ready for it to start up again hit the "NO" button and it will finish the encoding without a problem. I use this alot without problems when making VCDs even "pausing" a few times during a long process.
oops, read you post alittle closer. If you want to turn the system OFF it's more work but can be done.
1. During a long process hit STOP.
2. copy the partial output file to a safe location.
3. turn off computer.
- do whatever -
4. turn on computer.
5. load partial file and check frame count.
6. load origional source file.
7. goto the "Settings" button
8. goto the "Aadvanced" tab
9. select Source Range.
10. continue processing.
11. when complete use the "Merge & Cut" to paste the pieces together into your final file.
Works great for me...hope this helps. JimJohnD -
Forgot a step. 9a select one frame more than the frame count of the completed section as the start frame and the last frame as, well, the last frame. then continue...
How to continue with 2nd pass if you have .stats and .mbtree files?
By ad.vid in forum Blu-ray RippingReplies: 1Last Post: 21st Dec 2010, 14:28 -
Is it possible to force Ripbot to continue after crash/reboot?
By yorkman in forum Authoring (Blu-ray)Replies: 4Last Post: 12th May 2010, 19:37 -
Any reason to continue using my parallel printer cable?
By zzyzzx in forum ComputerReplies: 25Last Post: 19th Jun 2008, 07:51 -
How to choose continue video lighting (non-heat style) ?
By AAC in forum Newbie / General discussionsReplies: 0Last Post: 13th Mar 2008, 17:03 -
MISSING PROGRESS.APP hence the encoding doesnt continue
By drevinko in forum DVD RippingReplies: 1Last Post: 26th Feb 2008, 22:17
