I calculatet the Bitrate with the VCDhelp Bitrate Calc to get an DiVX Movie on exactly 2 74Min CD`s as a SVCD. But at the End the whole Movie was about 200MB bigger as it should have been.
What have i done wrong?
TIA
Sturchill
I'm a newbie, but did you use CBR or 2 pass VBR when you encoded? For CBR just enter the number from the calculator, for 2-pass VBR enter the number as the ave and set the max as desired.
I normally use 2 pass VBR (min=0, max=2000, ave=calculator) and the files are normally the correct size (although I add 10secs of padding ^_^). -
I used CBR. What is "ave"? Average?
Another Problem is that if i use higher Bitrates the Picture is stocking every 2 Seconds (But i am in the SVCD Norm). Probably it`s because of the DiVX. If i use Sefy`s Templates everything is working fine!
Cya
Miramax
<font size=-1>[ This Message was edited by: Sturchill on 2001-07-02 01:20:45 ]</font> -
If you are having playback problems at higher bitrates this could be your player/video card not being able to keep up. It is known to happen.
WinX DVD Ripper Platinum Ripping at Wrong Bitrate
By wperry1 in forum DVD RippingReplies: 14Last Post: 15th May 2015, 13:05 -
Philips 5990/12 - wrong aspect ratio @ DivX via USB
By blackfrogg in forum DVD & Blu-ray PlayersReplies: 9Last Post: 30th Jan 2009, 08:09 -
Entering Video Bitrate Makes Preset Switch To SVCD
By akulier in forum ffmpegX general discussionReplies: 7Last Post: 26th Feb 2008, 05:12 -
By akulier in forum ffmpegX general discussionReplies: 1Last Post: 21st Feb 2008, 04:31 -
Bitrate Calc Question
By cquetsch in forum Newbie / General discussionsReplies: 6Last Post: 24th Jun 2007, 18:11
