Im knew to captureing and I got a problem I got a geforce 3 card and i pluged the svideo cable to the card and to my tv , Im using tvtool and when i swith to tv mode my monitor is blank and so it tv I dont understand whats wrong and suggestions????????
On my card it will run the monitor and tv out at the same time....but on my friends ...the image is either on the monitor or TV not both....
Point here is that you probly need to see if there is a menu where you select which output to use...in your case s-video. Also check what the TV is set to display (ie input 1, 2, s-video...ect)
Then try again...chances are it is turning off monitor signal and sending out the signal some where ...you just aint getting it wher ya want -
I turned it on dual mode and i can see my monitor but nothing shows up on tv, I tryed video 1 2 and 3 , changed all kinds of settings it just wont show up on tv
finally got it to work but for some reason my divx movies look good but when I make them full screen they look like they are interlaced out the ass!
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 04:23 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 03:35 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 21:57 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 11:39 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 03:03
