If It is yes,How can I do it.?
I have taken mpeg files (that were captured using my Sony digicam) and converted them to mpeg2 using the mpeg2 plugin for Nero and burnt a SVCD. No trouble, just drag and drop. It looks pretty good too.
MattMatt -
Yes but it is pointless. The advantage of mpeg2 is that it supports interlaced video and mpeg1 doesn't. Just make an xVCD.
TMPGEnc will do it also www.tmpgenc.net
You will not gain any quality in MPEG2 from your MPEG1 source. I assume it is a compatability issue?Panasonic DMR-ES45VS, keep those discs a burnin'
DVD to MPEG Conversion
By Exodus119 in forum Video ConversionReplies: 2Last Post: 26th Feb 2010, 19:06 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 04:40 -
Conversion to MPEG-2 with as little loss as possible.
By PuzZLeR in forum Video ConversionReplies: 11Last Post: 1st Mar 2008, 07:50 -
mpeg-4 conversion help.
By ruk_design in forum Video ConversionReplies: 2Last Post: 28th May 2007, 03:18
