I'm thinking of getting a dvd writer and I was wondering... If I created a DVD and then moved on to other projects and deleted my source material, what is the easiest way to make a copy of the DVD I've already produced?
What's your favorite menu creation and encoding software?
Thanks!!
It should work fine to use any dvd copy program...like Neros dvd copier. If you want to copy DVD-Movies you read the DVD Ripping guides.
The best dvd authoring tool(menu creation and such) is DVDMaestro...but it is very expensive and complicated. Another authoring tools that are kinda good is Spruceup and DVD Moviefactory, simple buth with the few features.
how to block people from duplicating my external hardrive
By ltdg in forum ComputerReplies: 39Last Post: 21st Feb 2013, 06:44 -
Duplicating DVD-9 - more duds than DVD-5?
By sdsumike619 in forum Authoring (DVD)Replies: 4Last Post: 12th Mar 2008, 13:03 -
Decimating exactly to 25 from 29.97 (PAL-sourced - by duplicating frames)
By Alex_ander in forum RestorationReplies: 4Last Post: 21st Sep 2007, 04:02 -
DVDLab Pro: non-working links and duplicating item in play list
By daamon in forum Authoring (DVD)Replies: 6Last Post: 25th Jul 2007, 06:12 -
Duplicating people using adobe premier pro 2
By vipertongn in forum EditingReplies: 20Last Post: 12th Jul 2007, 01:07
