Hiya
Can we make new bin/cue files from the misc HD output of the DVD2SVCD conversion?
Here is my problem...I made the DVD2SVCD bin/cue files before realizing I put the wrong picture into the title page. Thus, I have a different movie screen shot as a title page...I would really like to correct this problem.
I would like to put in the correct picture without having to re-encode the entire vob file set (~20 hrs). Is there a way to do this?
Thanks to everyone in advance!
Homey
what I'd do is rip the smallest chapter to another directory with the correct title picture. As soon as it creates your title.mpg then you can close it out. Copy that title.mpg over in your movie you wish to correct and Recover from the 'muxing and authoring' point which should include the new title picture.
Hiya
I really appreciate your reply.
Could you be a little more specific on the 'muxing and authoring' point that I need to start from? Is there a way to do that from the new DVD2SVCD package or do I need the separate programs?
Why pick the smallest vob file to create a new batch from and not the first only?
As you can see I did post in newbee...I dont mean to waste your time, but this info is not out there. -
go to MISC tab and choose 'Recover' and then choosing muxing
why pick smallest...so you don't have to go through the entire process again and can get to the title pic encoding quicker.
Honestly though this isn't a newbie procedure per say but just pointing out it can be done with a little effort.
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 16:25 -
extracting the bin/cue from .oo1,.002 etc files
By belwas in forum Newbie / General discussionsReplies: 5Last Post: 7th Jan 2010, 01:59 -
Having trouble with .bin/.cue files
By UncleBose in forum Software PlayingReplies: 8Last Post: 12th Jan 2008, 07:06 -
The FilmMachine Xvid to SVCD conversion not creating Bin/Cue files
By louv68 in forum Video ConversionReplies: 2Last Post: 24th Jul 2007, 10:11 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 22:29
