I thought I posted this already???? Not showing up though. Here's the shortened version of my question:
How do i convert VHS to VCD and get nearly equivalent VHS quality when the VCD is played on a stand-alone DVD player? I dont care about playing on PC since I can simply open the file in any mpeg player (irfanview is my favorite and its free!)
Using
MMC7.6 w/Stinky capture via Video In (this is WAY too easy... must be missing something)
VCDEasy for burning (burning is too easy too so i figure im missing some step here)
Ive tried some stuff but quality is bad and sound is weak (even w/line-in record volume setting maxed out)
thanks
joel
First off the method may be correct...but its the tweaking in between that affect every thing....
Don't capture using a high compression setting or when you try to convert to bigger better ...it will be like trying to enlarge a 1in X 1in picture into a full screen photo.....
VCD standard is about 10 mb per minute for mpg video.... I seem to think my captures take about 50 mb a minute ( yours could be smaller)
When you encode you can adjust sound quality and volume...be try to get the best when you capture ...so you have something to work with.
hmm
By sve in forum TestReplies: 19Last Post: 29th Feb 2012, 03:15 -
PC - no POST
By pchan in forum ComputerReplies: 1Last Post: 29th Sep 2011, 10:22 -
Hmm, why can't I capture this video???
By Hal05154 in forum Video Streaming DownloadingReplies: 4Last Post: 16th Aug 2010, 17:56 -
post thanks?
By lordsmurf in forum FeedbackReplies: 7Last Post: 24th Feb 2010, 15:50 -
My first Post......
By Sophias012 in forum TestReplies: 0Last Post: 18th Jul 2008, 06:31
