does anyone recomend NOT using Nero to burn an .avi to a VCD?
If the quality is perfect I don't see a problem with it?
It will possibly come unstuck with certain avis, particularly because of the audio. Why not run a comparison with TMPGenc? However, if it works for you, and you are happy with the results, then fine. 8)
I don't recomend using Nero to burn Avi to VCD....
VCD's use mpg files ...so Nero most encode before burning.... the only problem there is that you dont have as much ( or any ) control over the encoding (file size or qualitycontrol).
Most people use TMPG or another program to encode to VCD compatable format then burn with Nero.
which is better Mainconcept MPEG Encoder or H.254 Encoder
By d_unbeliever in forum Newbie / General discussionsReplies: 7Last Post: 4th Aug 2012, 19:14 -
How it possible Video: X264 encoder with Matroska encoder extension?
By flash_os in forum Newbie / General discussionsReplies: 1Last Post: 11th Feb 2012, 10:13 -
Your Best Video Encoder/Re-encoder???
By iqbal88 in forum DVD RippingReplies: 2Last Post: 15th Aug 2011, 09:09 -
Error with Nero AAC encoder in XVID4PSP - "Could not open AAC encoder&
By TheViking in forum Video ConversionReplies: 2Last Post: 5th Nov 2009, 02:41 -
Nero Recode 3.1.2.0 -- "Nero Digital Standard" vs. "Nero Dig
By GrayStrickland in forum DVD RippingReplies: 1Last Post: 15th Dec 2008, 20:23
