  1. here's the scenerio....have a .cue and .bin file. tried to burn with nero but it is 3 minutes too long. my burner will not overburn. so i extract the svcd mpeg2 using mage. then i multiplex using tmpgenc/svcd settings, and the resulting svcd/mpeg2 file is smaller and i can then burn it. now i haven't had a chance to watch it, but i was wondering if what i did screwed the movie up or if it just magically got smaller. thought i'd ask to see if anyone has come across this or not.
    thanks for your time
    jfred
  2. I know this is a silly question, but did you burn the bin/cue as an image or as datafiles to the disk.
  3. i just used nero to burn image (cue/bin). but then it wouldn't let me because it said i didn't have enough room on the disk. my burner doesn't overburn. that's when i extracted the mpeg2 and multiplexed. then reburned with svcd mode in nero.
  4. You will just have to watch the movie to see if it worked. Cut/multiplex type work can be hit or miss depending on source and player.
    Panasonic DMR-ES45VS, keep those discs a burnin'
  5. thanks. i'm planning on it but thought i'd see if anyone else has tried it.
    appreciate the replies.
