Can anyone out there please tell me a way to find out if a certain vcd is in PAL or NTSC format. Thanx![]()
if you got a computer, it's very easy.
for windows :
insert the vcd and run the file MPEGAV\AVSEQ01.DAT in the windows media player.
then, file-> properties -> advanced options -> MPEG video decoder -> properties.
... and you got the frame rate.
29.97 for NTSC and 25 for PAL (and 23.smthg for NTSC also)
for linux... i think there's all details if you launch mplayer.Rico.
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 12:33 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 13:57 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 6th Dec 2009, 00:31 -
Creating NTSC Blu ray DVD From PAL TS Files. need help with NTSC format
By Rick0725 in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Apr 2009, 22:43 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 12:19
