  1. I finally produced a VCD that works in my DVD player using virtualdub, TMPgenc and burning with Nero! The Avi file was 255 MB. Now that I know how to convert to VCD.....I want to learn how to convert to SVCD. I tried to convert according to the walkthrough and found out really quick that the same file that fit on my CDRW as a vcd file would not even come close to fitting on my CDRW as a SVCD. Is there a compression tool needed to make it fit our will I have to use twice as many discs if I want SVCD quality?
    Thanx for the help!
    Did you use the tmpgenc wizard? if so you can specify how big the file should be.
    About 45-60 minutes on one SVCD is usually normal.
  3. i have found that if you want the quality, you gotta use the extra disks. but search the forum and you'll see it debated that a good svcd can fit on one disk, it's all in the settings. don't trust it myself, i'll stick with swapping them out and good quality.
