can I save the encoding project somehow and continue it later.If it's possible,how I do that?
Thank you!
Nope..unless you want to edit and remerge mpeg clips. If this
is ok for you then just press Stop and make a note of the
frame number. When you restart, you select the next frame
number as the starting point under advanced>source range.
At the end you have to use MpegTools to merge the mpeg clip(s)
together.
A better way might be to build up a few project files with a %
of the movie set to encode in each (so you conrol how long
the computer is occupied) OR do what I do.. set
priority to low when active, and minimise to the taskbar.
Problem With TMPGEnc
By Halibut72 in forum Video ConversionReplies: 2Last Post: 1st Oct 2008, 11:38 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41 -
tmpgenc 2.5 plus problem
By DSLGuy in forum Video ConversionReplies: 1Last Post: 3rd Apr 2008, 14:38 -
TMPGEnc Problem
By djkevyb in forum Newbie / General discussionsReplies: 3Last Post: 27th Sep 2007, 15:46 -
TMPGEnc Problem !!!!!!!!!!!!!
By homantam in forum Newbie / General discussionsReplies: 2Last Post: 10th Sep 2007, 17:56
