Hope someone can help..i have captured 2 files from my DV camcorder,
to my HD using Ulead Movie Factory. I then converted the files to mpeg2, using a CONSTANT bitrate of 6000.
When i use Workshop to make the disc, i either choose the template that is set for 6000, or i choose a CUSTOM template, and make the settings CONSTANT, 6000.
Either way, Workshop attempts to RE-ENCODE the video files.
I cant figure out why this is happening.
I've also tried to use a HIGHER bitrate setting or template,
and still it tries to re-encode the files. You would assume the
program would not try to UPCONVERT a file, but it does.
Finally, i gave up, and decided to let it re-encode the files, but twice
it came back with errors, saying that 'conversion failed', and this is
after spending 6+ hours doing it.
Anyone have any suggestions?
thanks
Winston
Results 1 to 1 of 1
Does anybody have Ulead DVD Workshop SE 1.21?
By OS_Man in forum Authoring (DVD)Replies: 5Last Post: 21st Sep 2010, 03:04 -
Ulead DVD Workshop 2 replacement?
By msimon7 in forum Authoring (DVD)Replies: 26Last Post: 2nd Sep 2010, 10:25 -
Replacement for Ulead dvd workshop 2
By jakewoodblues in forum Authoring (DVD)Replies: 3Last Post: 14th Apr 2010, 23:05 -
Ulead DVD Workshop 2 with Vista?
By SCDVD in forum Newbie / General discussionsReplies: 2Last Post: 17th Feb 2008, 03:48 -
Ulead DVD Workshop 2 error
By SEE_Studios in forum Newbie / General discussionsReplies: 21Last Post: 4th Jan 2008, 03:55
