ok I am new for doing S-VCD. It is normal it takes 14 hours for doing
s-vcd .
what i can do for doing it takes less time .to encoding.
I am runing with Pt 3 1000 mhz and 512 ram.Windows 98 second edition.
Somme body told me change your cpu witch PT 4 with dual 2.2 and overcloking and work with windows 2000 pro .and all will takes only 2 hours for doing S-VCD . It is true or what????????????????????????????
Im not sure if that would help or not.I would just run it while your asleep becuse if you decided to run a duel mobo exspecially 2 p42.2 it will cost you quite a bit of money actually too much your figuring roughly a $600.00+ dollar upgrade there.
This is proboly a ice cream induced thought so i can not take no control for the above statment. :P
Decrease Conversion Time
By CranialBlaze in forum Video ConversionReplies: 0Last Post: 10th Nov 2010, 05:23 -
Video Run Time Gets Cut in half - and other conversion problems...
By scotsgael in forum ffmpegX general discussionReplies: 0Last Post: 3rd May 2010, 02:41 -
Framerate conversion (again sorry) 60p to 25p this time
By Panash in forum Video ConversionReplies: 5Last Post: 2nd Jan 2010, 18:32 -
Removing a running time from vhs conversion
By eiffelgirl in forum EditingReplies: 10Last Post: 4th Dec 2008, 01:41 -
Problem Using Vider Studio 10 - Start Time After End Time
By jmsrickland in forum Newbie / General discussionsReplies: 0Last Post: 31st Jul 2008, 18:48
