Hi all
I always use CCE now and I usually use the same settings. However, I have also been using the same line in my avs file regarding bi-cubic resize no matter what the source, 16:9 or 4:3.
bicubicresize(480,576)
This is the line I use. Is this wrong? I haven't really noticed any difference but I thought I would ask.
Any help would be great, thanks.![]()
If your source is 4:3, there's nothing wrong with your bicubicresize.
However, if you have a 16:9 source and use the same resize parameters, you'll have to encode it as 16:9 too to keep the correct aspect ratio.
Problem is, some players have problems with 16:9 SVCDs. A safer way is to encode as letterboxed 4:3
BicubicResize(480,432)
AddBorders(0,72,0,72) -
Thanks,
So I should/could encode every svcd like this and only use add borders when the source is 16:9. When not 16:9 just use bicubicresize(480,432).
What is bicubic resize, what does it do?
Again thanks.
Should I use 640x480 or 320x480 with cubic for VHS capture
By groove365 in forum Capturing and VCRReplies: 4Last Post: 1st Sep 2010, 01:23 -
Resize HD to SD
By ron spencer in forum Authoring (Blu-ray)Replies: 9Last Post: 1st Jan 2009, 12:52 -
.sup resize...
By alcOre in forum SubtitleReplies: 1Last Post: 1st Dec 2008, 03:57 -
Advice on a new audio/video system(I need advice and direction)
By hellfire45 in forum Newbie / General discussionsReplies: 1Last Post: 14th May 2008, 23:20 -
Looking For Advice. I'm hoping to get some advice about a DVD burner
By wtsinnc in forum DVD & Blu-ray WritersReplies: 5Last Post: 4th Dec 2007, 22:39
