    Netherlands
    Hi,
    I'm trying to create a SVCD including multiple audio streams and more important...subtitles. Using the DVD2SVCD guide from doom9 i've succesfully created .cue and .bin files. However I have a challenge regarding my standalone DVD player.
    My Sony NS400 player cannot play SVCD movies. BUT by replacing the header of the MPG file with an MPEG-1 header I can trick Nero into thinking it is burning a VCD movie while it is a MPEG-2 (SVCD) encoded file.
    But because DVD2SVCD is a complete process which ends up with bin-image files I cannot replace the header of the MPG files. Also the folder structure of a SVCD is different from a VCD.
    Is it possible to create VCD movies with selectable subtitles/audio streams in the situation described here, or am I wasting my time.
  2. You are wasting your time.
    You can turn off vcdimager and check "don't delete files" under DVD2SVCD to stop bin/cue creation. Nero will take the muxed
    mpeg-2 files direct. BUT if you change the header and burn
    them as a VCD, the subs and extra audio will be lost as
    they are not supported under VCD specs.
    Netherlands
    Ok that's a possibility. But what will happen with the chapters and subtitles I had configured. Will I still get the SVCD folder structure, but then without it being put in a .bin file.
    Won't I just end up with only an .mpg file without selectable subtitles?
    Are selectable subtitles possible according to the VCD standard?
    Regards,
    Don
  4. Sorry... misread your post and did not see the bit about subs & audio
    See re-edited post above.
