After reading the suggestions elsewhere on this site, I use my Dazzle DVCII card to capture video at DVD quality at the highest CBR bitrate into a seperate audio and video file (.mpa and .m2v) with the supplied MovieStar software.
I then use the Standard VCD template that comes with TMPGenc to encode down to VCD. The audio and video are not synced in the resulting .mpg files.
I've also read that various audio and/or video codecs can cause this to happen somehow. I can't, however, figure out how to ensure that TMPGenc is using the correct codecs. Can anybody point me in the right direction?
Thanks!
Results 1 to 1 of 1
Audio Sync Problems
By nephesh in forum Video Streaming DownloadingReplies: 0Last Post: 12th May 2011, 08:10 -
Audio sync problems
By sticklebrick in forum Newbie / General discussionsReplies: 1Last Post: 13th Oct 2007, 14:14 -
audio sync prob dazzle dvc-150 and virtualdub
By zephxiii in forum Capturing and VCRReplies: 5Last Post: 30th Jul 2007, 13:34 -
Audio sync problems
By jelockwood in forum ffmpegX general discussionReplies: 1Last Post: 30th Jul 2007, 12:03 -
I've got audio sync problems (too)
By gigantibyte in forum EditingReplies: 26Last Post: 10th Jun 2007, 10:17
