When I play the xvcd that I made (using CCE to encode, bbmpeg to mux) the total time is not displayed correctly in Hiteker dvd player.
It showed about double the actual total time. Does anyone know where the problem come from ? Is it because of encoding or muxing. I see nothing wrong with these so far.
CCE settings:
mpeg 1, CBR, avg bitrate = 3200, quality = 17, antinoise = 6, write sequence end code
BBmpeg settings:
mpeg-1, pack size = 2324, video buffer = 230
It happens to me also,Windows says x
x,Nero says y:yy and media
and dvd player say z:zz. -
Happens on my Apex player too... Elapsed time seems correct, but Remaining time is usually off.
Originally Posted by tai01
If I make chapters on the svcd, there is no time display at all, just --:-- nothing else. -
Philips DVD players show the playtime for an SVCD encoded at max SVCD bitrate, so for 74 min CD it's 37 minutes and for 90 min CD it's 45 minutes. You can have chapters and the time display, if you turn PBC off.
xvcd is not standard - you expect some dvd player programmer to anticipae us making wierd xvcds instead of standard discs?
You give the programmers too much credit.Panasonic DMR-ES45VS, keep those discs a burnin' -
Originally Posted by RoopeT
Well, when I turn PBC off, I have Time-Display on my 712, but no more chapters etc. They are gone...
Total video time calculator??
By shentheory in forum MacReplies: 3Last Post: 2nd Nov 2011, 17:01 -
Total running time
By mrcoolekin in forum Authoring (DVD)Replies: 26Last Post: 15th May 2009, 01:38 -
Settings Correct? Taking a Long Time/.avi to DVD
By 5Buffalo in forum ffmpegX general discussionReplies: 3Last Post: 24th Dec 2008, 14:29 -
Display 3 subtitles at the same time on DVD
By Woogy in forum SubtitleReplies: 4Last Post: 29th Jul 2008, 09:28 -
TOTAL NOOB... how do u use WinAVI the correct way?
By bl@h in forum Authoring (DVD)Replies: 3Last Post: 19th Jun 2007, 14:57
