Hi everyone~ I'm a newbie in capturing and I've got some problems while converting VHS to VCD. I've got a VHS recorded in long-play (LP) mode. After converting to VCD format, the speed of the video is 1 time faster than normal. There's no problem in audio and converting short-play vhs. So how can I make the mpg file back to normal speed? Is there any software can solve such problem? Thanks!
I havent heard of this before... I've made VHS recordings at all speeds, SP, LP, and EP, and I haven't had any problems... cause if you have your vcr connected to your capture card, it should display on the computer as it does on a tv screen, which would be normal speed...
I had this kind of problem to.
with virtualdub I have changes in video speed and audio sync in the captured video.
With AVIO_IO I've never had this kind of problems. -
It does display on the computer as it does on a tv screen, the problem only occurs after recording as mpg file...
Sorry rajalev, what is AVIO_IO?
Weird problem converting VHS tapes
By bessiecat in forum Capturing and VCRReplies: 9Last Post: 3rd Mar 2012, 01:10 -
Converting VHS to digital, VHS tracking problems?
By ReedJohansson in forum Newbie / General discussionsReplies: 3Last Post: 23rd Jan 2012, 09:54 -
problem converting from NTSC VHS to dvdr
By skywalker9999 in forum Capturing and VCRReplies: 5Last Post: 11th Jan 2010, 04:22 -
Problem converting audio of VCD MPEG-1 to author DVDs
By Greycat in forum Video ConversionReplies: 6Last Post: 16th Jan 2008, 16:28 -
Problem converting avi to vcd using CCE
By Hittz in forum Newbie / General discussionsReplies: 4Last Post: 2nd Dec 2007, 20:27
