I'm a NEWBIE as they call it and have a few quick questions:
1. Is there a difference in the AVI & DIVIX formats (as software such as Ulead Movie factory, Nero 5.5, and VOB instant DVD) only mention converting the AVI & MPEG formats???
2. With that said, what is the most reliable software to go about doing this??
3. I currently have ADAPTEC easy cd creator 4 (installed w/ computer) i was wanting to upgrade but can't seem to find the nameADAPTEC anywhere, has Roxio taken over the process.
Thanks alot.
I'll attempt to answer your questions:Originally Posted by yragha
1) AVI=audio video interleave DIVX is a specific codec used to make avi files
2) for converting avi/divx-->mpg look at the left of this screen where it says CONVERT--you won't find better guides than those
3) yes, your adaptec is now called roxio. in my opinion, I would dump that and get something like Nero, or CDRWin, or maybe get VCDeasy, and daemontools, and then clonecd or something like that.
I used Roxio for a while, and made about 20 coasters without a single successful burn, and then switched to Nero, and have only made a few bad discs, but hundreds of good ones.
hope that helps.
what are you askin' me for...
I'm an idiot!
3d questions
By alucard2050 in forum DVB / IPTVReplies: 16Last Post: 22nd Aug 2010, 00:01 -
Few questions regarding LCD tv... that will lead to more questions :)
By ohlookyhere in forum DVB / IPTVReplies: 16Last Post: 15th Aug 2010, 16:50 -
Powersupply questions and fan questions
By yoda313 in forum ComputerReplies: 39Last Post: 8th Sep 2008, 19:08 -
SD to HD Questions
By The Sumerian in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 21st Nov 2007, 12:08 -
Got a new 16:9 TV, have some questions...
By sdsumike619 in forum Video ConversionReplies: 6Last Post: 28th Jul 2007, 15:00
