By now I have become used to using tmpgenc and VirtualDub to create files for burning through VCDEasy.
But surely there must be an easier way? An automatic way!
Is it possible to script or automate the process in anyway? I would love to be able to give a filename (or list of filenames) set the program(s) running and wake up in the morning when all is finished.
Someone must able to help!
There are easier ways if you don't care about quality, and will accept the odd encode with wrong aspect ratio and no sound.
The best way is with TMPGenc. If you want to automate the process you can set up a list of jobs for it to do. File>Add current job to batch list... -
The batch process in tmpgenc I have used before. I noticed a batch system in VirtualDub also.. but couldnt find a way of creating the jobs to pass to it
File>Save avi then tick *add operation to job list and defer processing*. When you have assembled all your jobs go to File>Job Control (or hit F4).
Vobs, making them easier to use.
By nickhopkins07 in forum Video ConversionReplies: 2Last Post: 14th Sep 2010, 15:45 -
Is it easier on the burner to use R or RW media?
By PuzZLeR in forum DVD & Blu-ray RecordersReplies: 25Last Post: 28th Nov 2008, 11:40 -
Subtitles: easier way to create them?
By tirengarfio in forum Newbie / General discussionsReplies: 5Last Post: 5th Apr 2008, 23:43 -
Easier way to schedule captures
By 4evrplan in forum Capturing and VCRReplies: 6Last Post: 3rd Oct 2007, 23:04 -
Something faster/easier than AutoGK/FUW?
By RabidDog in forum Newbie / General discussionsReplies: 2Last Post: 3rd Sep 2007, 15:37
