I have a VCD which I can't copy as I get read errors with any copying program like CloneCD.
I have tried just copying the dat file to my hard drive but this fails.
I did manage to get it copyed with ISO Buster but the file has 2 errors.
I have tried to fix the errors with VCD gear but no luck.
If I add the file to VCD Easy, as I want to make chapters it fails at the errors.
I have tried to de-multiplex with TMPEGEnc and Cut the errors out with VCD Cutter but the errors wont allow it.
The disc does play ok all the way past the errors on my DVD player with only a slight blip.
Can anyone help me fix it?
How about loading into TMPGEnc merge/cut and set source range passed the error.
Other than that, tell the disk copy program to Ignore errors ? -
I had tried to cut with TMPGEnc past the errors but it wont allow it. I think this is because it scans the file from the start but can't get past the errors.
I will try clone without errors checked. I still wont get a VCD with chapters!
DVD ReMake Pro! join issue!!
By Shohag_ifas in forum Authoring (DVD)Replies: 7Last Post: 25th Dec 2010, 23:03 -
DVD back in my PC to remake new movies?
By fishtk75 in forum Newbie / General discussionsReplies: 10Last Post: 23rd Apr 2008, 05:52 -
DVD Remake Pro 3.1.4 issue
By ashoun in forum Authoring (DVD)Replies: 3Last Post: 27th Feb 2008, 12:49 -
DVD Remake Pro deletes my firstplay?
By lordsmurf in forum Newbie / General discussionsReplies: 8Last Post: 18th Jul 2007, 02:10 -
Remake casting call
By Marco33 in forum Off topicReplies: 6Last Post: 5th Jun 2007, 01:18
