does any body know a program that can do this? i have a 3.3 gig m2v file and a 290 mb ac3 file, tmpge will only mutiplex a svcd or mpeg2 program file, i need to mutiplex to dvd spec. anybody know?
If you use SpruceUp just put mpv and ac3 files with the same name (i.e. film.mpv and film.ac3) to the same folder and import mpv file. SpruceUp will take ac3 file automatically. This will save time also because SpruceUp will not have to demux mpeg before creating vobs.
Or use Maestro instead of SpruceUp, as I mentioned in another thread. Maestro is much more advanced than SpruceUp. You may create anything you see in commercial DVDs using it.
... Yeah, and it is so much more expensive!"There is always one more bug."
No bugs at http://www.iGorland.com -
Maestro will do it, but you will have to sell your car to buy it. I hear it is great, but I have never used it. SpruceUp will take an encoded AC3 file, so will ReelDVD. WinDVD PE will change a 5.1 AC3 to 2.0 AC3, but it has the encoder built in to do the 2.0AC3. I don't think you can use TMPGEnc or BBmpeg to mux an AC3 file with m2v. But I may be wrong. Scenarist will also do it, but you have the same $$$$$$$$$$$$$$ issue that you have with Maestro.
Just a quick show of hands. How many people here using Maestro actually PAID for it? LOL
i tried spruce, but when a import the files it hangs at 99% ,i left it for like 45 minutes and it still hung, does anybody have a older version of spruce demo? if you got it maybe we can trade?
thanks
How to convert a AAC audio file in a mkv file to AC3?
By wolvie77 in forum AudioReplies: 4Last Post: 13th Mar 2012, 21:59 -
Transform .m2v +. wav to full MPEG-2 dvd spec file?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 2Last Post: 14th Oct 2011, 08:13 -
Muxing .m2v & .ac3 to .TS file
By randronoth in forum Video ConversionReplies: 3Last Post: 21st Jun 2011, 02:21 -
How to convet mpv file to m2v file format?
By Bonie81 in forum Newbie / General discussionsReplies: 4Last Post: 28th Oct 2010, 06:17 -
toast won't do wav, so using mpg file instead of m2v file gets round that?
By jboyd in forum ffmpegX general discussionReplies: 12Last Post: 16th Nov 2007, 14:08
