Hi,
*sigh* I have Nero installed on my computer. I have successfully been able to burn off music cds. My question is this: what steps need to be taken to burn off an .avi file? I've noticed that the majority of video files are.avi. As a newbie I thought burning a video was as simple as burning off mp3s.I'm using Kazaa by the way, and cannot view the .avi file when it's downloading? Why is that? Or do I just need to wait till it's finished and view it in Windows Media Player? I'm confused by all the divd, divx, dvd etc terms lol Any help explaining how I can burn off an .avi file would be greatly appreciated...thanx! Sorry for the dumbness lol
""how I can burn off an .avi file ""
What !?
The *.avi file you have downloaded is most likely a mpeg4 (divx) video
In order to view on a television you must either have a video card with TV out and run the file from the computer OR re encode into a format that standalone DVD's will recoginize.
Most standalone will play the VCD standard
Ahh but but how do i do that
<---------- read the HOW TO then return enlightened -
Don't worry, you can simply burn your avis as regular files, just like mp3s or others.
Things are different if you want to burn a VCD (Video CD) or SVCD (Super Video CD) that you can play back on a standalone DVD-Player: These have to be written in a special format, and since VCD and SVCD are based on mpeg 1 and 2 respectively, you'd have to convert your avi into one of these video-formats before you can use it for a (S)VCD.
Freshman -
thanx both of you, and freshman...YOU answered my question(s)..thank you...
Confused about Levels
By Smells_Like_Feet in forum RestorationReplies: 2Last Post: 4th Mar 2012, 08:51 -
Confused! Confused! Confused! VCR to DVD; major question Toshiba Diomage SV
By CAnn12 in forum Capturing and VCRReplies: 0Last Post: 5th Feb 2011, 11:26 -
Confused with Encoding
By skorpinok in forum Video ConversionReplies: 3Last Post: 29th Aug 2010, 10:40 -
Confused about XP cd reformat
By neworldman in forum ComputerReplies: 5Last Post: 22nd Jun 2010, 08:36 -
Confused about 1080p
By gauche in forum Newbie / General discussionsReplies: 4Last Post: 18th Jan 2009, 08:51
