I'm new to conversion. I bought a Snazzi Video capture card recently. I have lots of karoake laserdisk and would like to tranfer them to VCD but
don't know how???. Anyone there can help?
Connect Laserdisc video out to snazzi video in. Same for audio out to audio in.
Load up the snazzi video capture program. Set parameters for MPEG1 capture, 352x240, 29.97 fps, 1150 kb/s (US) then press record. Press play button on LD.
When you have the MPEG file, look at the Author section of this site on getting the MPEG into VCD format.
If you capture card captures only AVI, look at the Convert section on converting an AVI to MPEG1.Panasonic DMR-ES45VS, keep those discs a burnin' -
Thanks a lot Kitty.. Next question for you. How do I get both the analog and digital sound from the laserdisk so that I can switch on and off!!
my PCs can't detect disc format of VCD from Thailand
By Foobar in forum Software PlayingReplies: 2Last Post: 6th Jan 2011, 11:10 -
What's the best format and resolution for LCD TV or HDTV from DVD and VCD.
By newbievideohelp in forum Video ConversionReplies: 6Last Post: 6th Nov 2009, 14:23 -
Problems converting AVI to vcd format using TMPGenc 2.5 Plus
By peterock in forum Video ConversionReplies: 2Last Post: 28th Dec 2008, 16:34 -
How to convert E-Book in PDF Format to VCD or DVD
By permataharahap in forum Newbie / General discussionsReplies: 2Last Post: 29th Jul 2008, 01:00 -
Settings to convert WMV to VCD/DVD-playable format?
By pingosimon in forum ffmpegX general discussionReplies: 5Last Post: 16th Jul 2007, 18:53
