hi everyone,just wondering if someone can help me.id like to know how i can rip the special features or if i can rip them.cheers hipster
What do you mean when you say "special features"????? You mean like the trailer, Deleted scenes?
If so, use Power DVDxp and goto browes media files, start opening some of the smaller vob's and see if those are the ones you want. Then when ripping with smartripper go under 'Files' and select the vob in question. Hope this helps!!!
The best thing to do, is to just rip the entire DVD to your hard drive, using the FILES option in SR and selecting ALL. Then you can take your time in deciding what you want to keep and what goes into the garbage.
Thats what I was saying, what I was saying is you can do all that w/o ripping the whole disk and saving time by just browsing the disk w/ player software.
If you have plenty of HDD space, just ripping the whole thing and working it out later is probably faster -- especially with FlaskMPEG and/or DVD2AVI.
Regards.Michael Tam
w: Morsels of Evidence
Can't find special features with DVD Shrink
By neworldman in forum DVD RippingReplies: 6Last Post: 9th May 2010, 01:56 -
how do i rip special features off a dvd?
By username1 in forum DVD RippingReplies: 4Last Post: 6th Apr 2010, 19:18 -
Can't access Special Features
By wulf109 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 3rd Sep 2008, 14:55 -
special sub+idx
By akusoul in forum SubtitleReplies: 6Last Post: 6th Apr 2008, 06:00 -
Features
By Jedi_Knight in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 29th May 2007, 19:29
