im doing my own movies using smart ripper,rempeg and spruceup.evrything is ok except i cannot seem to find the original main movie menu,so i have to put a home made cheesy verion in which makes the movie look very tacky to say the least.so what i need to know dudez is where do i find the main movie menu and how do i get it into my ripped dvd movie so it looks like the real thing.....THANKS.
The main movie menu is usually in VTS_01_0.VOB. When you rip the movie, just use the FILES option and check ALL for all files. Then use VOBRATOR to walk through (and map) all the VOB IDs as to their function. Don't worry, it's not as hard as it sounds. After two or three of these, you'll be able to identify the menu in a snap.
Replacing the main video in a DVD
By DeathStalker77 in forum Authoring (DVD)Replies: 9Last Post: 20th May 2010, 16:17 -
Convert main movie from DVD to TS.
By Puni in forum Video ConversionReplies: 4Last Post: 19th Feb 2010, 07:42 -
Backup main movie from DVD9 to DVD5 with main & chapter menu's.
By ChibiTomo in forum User guidesReplies: 18Last Post: 18th Jan 2010, 19:27 -
Play vs Resume Main Menus
By ecc in forum Authoring (DVD)Replies: 2Last Post: 19th Apr 2009, 07:52 -
How to full backup (no encoding) BR main movie, main audio with subtitles ?
By meico1234 in forum Blu-ray RippingReplies: 2Last Post: 2nd Feb 2009, 03:37
