ok, I opened my Divx file with virtualdub and ran audio as .wav file.
opened Tmpgenc and put divx as vid and wav as Aud... now when I play back on my computer it's out of sync.
its not my specs cause I been doing this for over a year-this is my first SVCD from divx though...anybody?
do you play the svcd with windvd or powerdvd? dont use media player because it can sometimes cause sync problems while playing svcds.
if it still is out of sync
did you use change the framerate? ntsc to pal or something? -
man your good....did the trick..had no way of checking on my standalone, doesn't play em, Im doing it for a friend...
Know any good cheap players? I heard Apex, but some dont, right?
Thanks for the tip...
Apex1200, circuitcity $65, will do the trick if you want costs low & VCD/SVCD/x(S)VCD compatability.
Panasonic DMR-ES45VS, keep those discs a burnin'
Outta sync issues after converting MKV's
By snowseals in forum Video ConversionReplies: 2Last Post: 1st Jan 2012, 06:56 -
Aiwa HV-MX100 display doesn't light up & stop button doesn't work
By TurboJoe in forum Newbie / General discussionsReplies: 15Last Post: 12th Feb 2011, 19:07 -
Converting Divx-AVI to MP4 - Output size option doesn't work
By tomzero in forum ffmpegX general discussionReplies: 6Last Post: 20th Mar 2010, 08:30 -
DivX created by ffmpegX doesn't work on player?
By ambrosechapel in forum ffmpegX general discussionReplies: 7Last Post: 17th Oct 2008, 08:13 -
PAL to NTSC..FAVSC doesn't work anymore and BeSweet Doesn't give me some op
By sandman423 in forum Video ConversionReplies: 13Last Post: 11th Mar 2008, 06:58
