When i follow the All-In-One DivX to VCD guide to making DivX to VCD each rip when played on a DVD player doesnt come out clear. Every 4 to 5 seconds blocks show up either in remote locations or a bunch of colored blocks flash on the screen. I did some research on the ripping and converting process and couldnt find much on this subject except one lil section in the tmpge section called sharpen edge, which i checkmarked the box. Has anyone else had this problem or know of a way to correct this issue? Thanks
make sure you dont have the angel potion codec installed. its notorious for ******* up divx to vcd encodes.
thanks for the advice. i took out angel potion, and the picture comes out clearer with not as much interference, but i still get those lil boxes any other advice?
i had the same problem but got informed that this is part of the mpeg2 codec. nothing you can do but turn up the bitrate or use SVCD instead. it usually comes up in darker parts of the movie right?
yes or in quick scene changes. it comes out clear when i play the movie file on my computer but when i burn it to a cd to play on my dvd player, it comes up with those intermittent squares
see that's the weird thing. it happens to me on both powerdvd on my computer and my apex dvd player. many people recommend turning down the burning speed when playing it on an external dvd player like 4x since some dvd players can't handle the speed. don't know if its true or not but you can try it and see if it helps you. i know i have and it hasn't made a difference.
Mpcstar pixelation problems picture becomes clumped squares
By kakashi9401 in forum Software PlayingReplies: 0Last Post: 15th Jul 2010, 13:52 -
[SUPER] iPod on TV conversion problems (heavier and lots of squares)
By Horrigan in forum Video ConversionReplies: 9Last Post: 24th Mar 2009, 23:02 -
Problems playing Divx / Xvid files on Silvercrest KH 6508
By Onihoshi in forum DVD & Blu-ray PlayersReplies: 7Last Post: 11th Oct 2008, 15:18 -
why do cds or dvds stick or show squares or slow down when playing?
By wan2no in forum Newbie / General discussionsReplies: 12Last Post: 4th Apr 2008, 21:09 -
Squares Appear When Playing Online Games - Resolved
By HacktheHacker in forum Software PlayingReplies: 6Last Post: 20th Jan 2008, 16:07
