I RECENTLY DOWNLOADED JURASSIC PARK3.ITS ABOUT 400MB.IT PLAYS FINE ON MY COMPUTER,BUT WHEN I TRY TO ENCODE WITH TMPEG IT SAYS INVALID FORMAT.I TRIED TMPEG A,B,AND I.THEY ARE EITHER NOT SUPPORTED,OR JUST ENCODE AUDIO.I ALSO TRIED CHANGING THE PRIORITY IN THE ENVIROMENTAL SETTINGS.IF ANYBODY THINKS THEY CAN HELP,I'D LOVE TO HEAR A SOLUTION.
Results 1 to 9 of 9
I guess, you need the codec, that is used to compress the avi.
ripper where did u download it and i'll go and have a look for you as to why it's not converting properly.
U can try & download the older codec from http://www.doom9.net as I usually get crap using the newer one, dvix 3.11 alpha. This should hopefully sort out your problem.
Kev -
Kev -
Kev -
Check the properties of the avi and see what the resolution (352x240 for NTSC) is, which framerate was used, and which Codec should be used.
How to rip DVD to 400mb .mkv?
By iqbal88 in forum DVD RippingReplies: 11Last Post: 7th Aug 2011, 03:34 -
Premiere Pro CS4 outputs 400MB file from 5MB original?
By J-E-T-S in forum EditingReplies: 5Last Post: 20th Jul 2009, 19:46 -
Seeking expert advice - Mkv to AVI + Subs (Mencoder)
By izzy2k in forum Video ConversionReplies: 2Last Post: 7th Apr 2009, 10:28 -
Opinion: MP4 or AVI?
By chopdog1777 in forum Video ConversionReplies: 5Last Post: 3rd Oct 2007, 18:40 -
Need an expert advise on converting AVI (or SWF) to MPG High quality video
By oavs in forum Video ConversionReplies: 10Last Post: 10th Jul 2007, 15:41
