I am trying to converta ripped DVD to VCD. I can load the avi files into Virual Dub and when i try to decompress the audio files and save it as a wav file is throws up an error message referring to "the audio compression is not supported by the audio format" i have tried various settings can anybody help please.
Thanks anyway but i managed to find a solution i needed the ac3 codecs as it was a divx-dvl file
Hey, I have the same exact problem with an AVI I am trying to convert to VCD. Shallow Hal.
I have a screen shot from Virtual Dub of the File Information. This is what I am doing, like chip tech It hink.
[list]
1) Open AVI (DIVX) in Virtual Dub 1.4.10
2) Turn on Full Porocessing mode, choose NO COMPRESSION (PCM) and the convert it to 44100 Hz
3) Save WAV[list]
Ge the following error:
The requested audio compression is not compatible with the input format. Check that the sampling rate and channel count of the input match those of the requested format.
Then hit OK.
Since I don't think I can upload teh picture of the FILE INFORMATION here it is:
Audio Stream
Sampling Rate: 48000 Hz
Channels: 5 (Stereo)
Sample Precision: 0-bit
Compression: Unknown (tag 2000)
Preload skew: 24000 samples (0.50s)
# of frames: 798222
Min/avg/max/total frame size: 960/1920/24000 (149687K)
I can play it in Windows Media Player and the audio compression is listed as something I cannot recall. 3 words ... 2 of the words began with M and one was an Irsih sounding name I think. I did a search on teh web for this format and it said somethign about multi lingual audio support or something.
I can find that info out later if needed.
Is there a way to have Virtual Dub look at teh same decompressors as Media Player? Does that even make sense? Any help would be appreciated.
Thanks. -
try downloading and instaling the ac3 codec, if media player gives you sound and vision then Virtual Dub should also then be able to pick up the codecs too. it worked for me i burnt it to vcd using nero and viewed it this afternoon on my standalone dvd player
Good luck
Vcd audio problems
By Ak_wf1 in forum AudioReplies: 5Last Post: 26th Nov 2011, 20:19 -
Vcd audio problems
By Ak_wf1 in forum Authoring (VCD/SVCD)Replies: 1Last Post: 26th Nov 2011, 19:59 -
Problems with DVD to VCD, including no audio. Help!
By gastrof in forum Newbie / General discussionsReplies: 8Last Post: 4th Jan 2008, 12:39 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 06:54 -
Follow up : audio problems with VCD authoring
By thelotusman in forum Authoring (VCD/SVCD)Replies: 5Last Post: 9th Jun 2007, 18:34
