My DVD player can play raw MPEG files, and I was wondering if there was a simple way to add tracks (like VCDeasy does with VCD) to the MPEG before burning it as a data file to DVD-R? Can this be done during encoding with TMPGEnc?
I think you'll find that's not possible with a raw file, as it only has 2 streams - audio & video. You'd have to use some form of authoring software, add the tracks and encapsulate into a recognised format that supports multiple tracks.
Most DVD authoring packages let you have several audio tracks, but to run several video tracks (multi-angle) you start getting into serious production software. Sonic DVD-Producer & Pinnacle Impression DVD-Pro will both do it if I remember correctly.
Alex -
Try Daikin's Scenarist (now Sonic's Scenarist)
The hardest to learn, but the most powerful of them all. As Doom9 page says: ..." It's the mother of all DVD authoring programs"...In this industry, Sadly, The future was yesterday.
Good software to add/ sync audio tracks?
By jiopi in forum EditingReplies: 2Last Post: 14th Feb 2011, 07:25 -
DVD to MPEG2, extract mult audio tracks, subtitles for replay in WD TV Live
By Jacoman in forum DVD RippingReplies: 5Last Post: 16th Mar 2010, 09:40 -
Add an 2 video/Audio tracks to a .mov file without using Quicktime
By thomas31388 in forum Video ConversionReplies: 0Last Post: 24th Sep 2008, 15:35 -
how to: add 2 mono tracks = 2 channel wave?
By spiritgumm in forum AudioReplies: 4Last Post: 7th Sep 2007, 16:52 -
How to add multiple audio tracks in DVDMaestro?
By rbatty11 in forum Authoring (DVD)Replies: 0Last Post: 5th Sep 2007, 07:48
