I have been using .wmv to capture tv episodes because its a lot smaller than mpeg2 and the quality is acceptable to me. But what format is best in terms of size and quality? I'm trying to fit these recordings on a CDR.
Would recording in mpeg2, then converting to divx work?
If you're happy with Windows Media files, then you will not find anything else that will make smaller files and give the same or better quality. Mpeg-2 require a lot higher bit rate. Divx and Windows Media files are pretty close, divx is made from a Microsoft compressor.
But if I really wanted to convert from mpg2 to divx, what program should I use?
Best format to capture in?
By Canopus Smoker in forum Newbie / General discussionsReplies: 10Last Post: 27th Nov 2008, 14:14 -
Anyone download the payware FUNimation episodes in WMV format?
By FulciLives in forum Video ConversionReplies: 2Last Post: 25th Aug 2008, 09:19 -
what is the best format when capture from tv show?
By sumeshkri in forum Capturing and VCRReplies: 10Last Post: 23rd Feb 2008, 18:35 -
WMV Format Capture
By zerohash in forum Capturing and VCRReplies: 1Last Post: 7th Aug 2007, 08:48 -
best capture format and software
By boots in forum Capturing and VCRReplies: 11Last Post: 27th Jun 2007, 19:54
