I followed all the instructions given in the tutorial of how to capture live TV to AVI with various codecs. I used the PICvideo codec. And didn't get sound, I used other codecs, and still didn't get sound. When i use the software that came with my Pinnacle PCTV pro, sound works fine. Please advise me. Thank you!
P3 1000 mhz
384 mb pc133 sdram
20 gb harddrive
Geforce 2 MX 400 ultra
w/ onboard sound
somebody needs to create a counter for this specific question, I mean my GOOOOOOOOOOOOOOOOODDDDDDDDDDDDDDDDDD!
look left and check the capture guide and look at the problem solving solutions at the bottom of the page.
It's almost as if people automatically click Forum and ignore the in-depth guides that are right in fron of their eyes.
AHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHH! -
Make sure you have checked "Line In" in your mixer's "Recording" section. Your TV Card's software could be automatically doing this, and therefore works fine. VirtualDub doesn't check/change this setting. Mixer (or Volume Control) is in Accessories->Multimedia
No Sound With Dazzle DVC100 using Virtual Dub
By kpoman in forum Capturing and VCRReplies: 3Last Post: 3rd Nov 2009, 09:35 -
Virtual dub
By santolina in forum Newbie / General discussionsReplies: 4Last Post: 22nd Jul 2009, 14:48 -
Virtual Dub problem
By rocka in forum EditingReplies: 3Last Post: 2nd Jan 2009, 04:46 -
help with virtual dub
By Remyisme in forum Newbie / General discussionsReplies: 7Last Post: 30th Jan 2008, 16:36 -
how can I specify the resolution when capturing in virtual dub?
By Onceler2 in forum Capturing and VCRReplies: 3Last Post: 28th Jan 2008, 11:11
