  1. I have a Geforce 3 as my main video card in my Windows XP machine. What I am wondering is if I can install my ATI all in Wonder card and use it solely for Video Capture? Dont know if it will work or not but figure someone has probably tried it. Thanks in advance.
  2. Technically Yes. You can have both cards running in your PC. This is assuming that:
    1) Both Video Cards are PCI
    2) One card is AGP and the other is PCI
    3) Your MB has an available slot and IRQ
    4) I'm also assuming that you are technical.
    In a AGP/PCI config you will need to enter your BIOS and set the AGP card as your primary display.
    In a PCI/PCI config both cards are primary. You will need to plug your monitor into the card you choose to be primary.
    D
