ok, to rip a dvd u end up with .vob files. when u re-encode these files at another bitrate u end up with an .mpg file. now what i want to do is convert the mpg back to VOB without authoring, because i do not want a menu. dvd movie factory can do this but unfortunately it does not support ac3 sound...is there anything else i can try?
Results 1 to 9 of 9
I am curious why you would want to do that...... if you want vob's just use the ones you ripped off the DVD....You can play them straight off the hard drive with most software DVD programs... And there is no menu...those vob's are just the movie you ripped.
because the VOBs are from a dual layered dvd, the VOBs are too big to put onto a DVD-R without re-encoding to a lower bitrate first
OK good answer..but you don't have to go back to vob...You can reduce bit rate by encoding with TMPG to DVD Mpeg2 .... Smaller file size but higher quality than the VCD or SVCD .....Almost DVD
There is a instruction/how to at
http://www.vcdhelp.com/tmpgencdvd.htm -
i dont think you understand...i know how to do that already...i AM using TMPGenc to get the VOBs to MPEG-2. But to burn this back to DVD the MPEG-2 needs to be 'authored' to be converted back to the VOBs, cause thats all a DVD Player will recognize. You cant just burn the mpeg2 onto a dvd and expect it to play.
Get imgtool from doom9, i think it can easily mux and author mpeg to vobs without menus and stuff.
and after you made the vob you can make the ifos with ifoedit ...I also think...I haven't tested it yet.
DVation,
If you are re-encoding the movie then you would be better off reauthoring the DVD. If you have re-encoded then you have lost your chapter points. Even if this does not matter to you there is still the issue of finding some app that can accurately map your VOBS. I love IfoEdit but I am not convinced that it can do this. If you’re trying this so you can preserve AC3 then 'look' around for a copy of SpruceUp. While this app is no longer commercially available it can be found if you 'look' with some persistence.
D
No audio when saving .MPEG file from VOB stream using MPEG Streamclip?
By Bix in forum MacReplies: 3Last Post: 25th Jul 2010, 17:12 -
Converting .VOB to MPEG-2
By PHNeedsHelp in forum Video ConversionReplies: 2Last Post: 21st Jul 2010, 12:22 -
vob and mpeg to dvd
By Dekaspace in forum Newbie / General discussionsReplies: 2Last Post: 3rd Jul 2008, 18:36 -
Can't encode VOB to MPEG-2
By radellaf in forum ffmpegX general discussionReplies: 3Last Post: 11th Jun 2008, 19:08 -
Vob to mpeg-2 question
By ChrisXP in forum Newbie / General discussionsReplies: 4Last Post: 6th May 2008, 23:16
