  1. Anyone know how to use the menu page option in Nero? I tried adding a menu page to a VCD burn and when I played the VCD that's all that showed up was the menu, the video itself was nowhere to be found. There must be somewhere I can adjust the duration for the menu page, but I can't seem to find it anywhere! Please help!
  2. When you go to the menu page before you burn, there is a box that asks for the duration of the time in between the menus and the video. After you have burned your vcd and your menu appears, you must use the remote on your dvd player. Press "1" to go to the first video, "2" for the second, etc. I'm not looking at my nero program right now, so e-mail me if you have any other questions.
    Hope that helps!
  3. Member MaDmiZe's Avatar
    May 2002
    City of...Atlanta
    I think the menu stays up no matter what you set the pause for....It just stays up till you tell it to play a video buy pushing a number.
    Best I can tell the pause affect the gap between two videos on same cd ...if its set to "0" then it goes right to next one ...but if its a number then it waits that amount of time before proceeding.
    If you are saying that there is no other stuf on the VCD...check it on your pC and look for the dat file (its in a folder on the disk...not in the root directory)....It will be ruffly the same size as the originial video file.
