i know everyone always posts on here asking how to make chapters seemlessly.
here's my situation.
i rip dvds to the hard drive with smartripper, splitting and making a new .vob file for every chapter.
is there software that will perform a batch encoding of .vob to .mpg so that i can translate dvd chapters to svcd tracks?
i have been using flask, but maybe there's a plugin for doing batches or something?
thanks!
THIS IS HARDCORE
FlasK uses all the .vob file as one logical file, this is dvd mode. I guess you should put the first vob file in a seperate subdirectory to avoid the dvd mode, maybe you need a directory for each vob file.
Also consider to use DVD2AVI instead of FlasK. Create a project file of each vob and use TMPG's batch encode mode.
I guess after you'll do this hard work, you want to burn it as multitrack SVCD? I think, this is not worth the trouble. But try and see. -
i suppose we will see. i guess the ability to get seamless chapters is what it all depends on.
thanks though.
one thing. would the dvd2avi step require my intervention between every file? or is there a batch process for dvd2avi as well?
thanks.
ps. in flask, when doing a conversion, what does the tab "run in batch mode" do? i don't know how to use it.
THIS IS HARDCORE -
dvd2avi does not have a batch mode. And flask?...I don't know, sorry.
AVStoDVD Chapter help?
By uEih in forum Authoring (DVD)Replies: 0Last Post: 24th Nov 2009, 06:34 -
diving one chapter into several ones
By jony2 in forum Authoring (DVD)Replies: 1Last Post: 13th Apr 2009, 10:26 -
GUI for dvdauthor - How to make chapter thumbnails run the chapter video
By deco81 in forum Authoring (DVD)Replies: 4Last Post: 15th Dec 2008, 11:51 -
Chapter Tool?
By pepegot1 in forum Authoring (DVD)Replies: 2Last Post: 17th Aug 2007, 09:55 -
Chapter question
By BCbear in forum Authoring (DVD)Replies: 15Last Post: 30th Jun 2007, 08:52
