  1. Ive just d/l'd the latest VD&Tmpge , can someone tell me why its taking
    ages to convert to mpeg,i used both of these product's before(must of been older versions) and it use to only take half an hour to do half a
    movie, ive got the latest codec + player. im using a 1900 proceser
    Any help would be great, cheers
  2. Member MaDmiZe's Avatar
    May 2002
    City of...Atlanta
    You got me...the more u ask it to do the longer it takes ....but I have had some take almost 24 hours to encode one movie..
  3. im going to give it a go with some old version ones ive just d/l'd
    i will let you know how i get on with it.
