I am trying to make a VCD in CCE. I am using a DVD source and I am frameserving with avisynth. The source movie is 4:3 aspect.
Now for the problem, when I encode the movie there are black bars at the top and bottom of the screen. The black bars souldn't be there, why is it doing that? My avisynth script is as follows:
LoadPlugin("C:\MPEG2DEC.dll")
mpeg2source("C:\Movie.d2v")
BicubicResize(352,240)
I have also tried BicubicResize(352,480) and set half vertical res. in CCE and same results.
I don't see why the black bars are there. Can someone help me out?
You say the movie is 4:3 but does it play back fullscreen with no bars? If there are bars when playing the DVD then they are encoded in the original. When are the bars showing up? If its in your software player, you might need to look for a toggle in the player to "Keep Aspect Ratio" or something of that nature. Also make sure you have selected your output in CCE to be 4:3. There is nothing in your script that would cause this to happen.
I found out what it was. There was nothing wrong with it, I made a sample movie and copied it to a disc and it played full screen in my DVD player. Maybe I sould have tried that first but thanks anyways.
Making a VCD to send to the Philippines
By StrikerZERO in forum Authoring (VCD/SVCD)Replies: 17Last Post: 7th Dec 2010, 09:11 -
Need advice on making dvd copies and making ISO files please.Thanks!
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 1Last Post: 17th Jan 2008, 12:03 -
Problem converting avi to vcd using CCE
By Hittz in forum Newbie / General discussionsReplies: 4Last Post: 2nd Dec 2007, 20:27 -
Making VCD Copy
By audiophile in forum Authoring (VCD/SVCD)Replies: 5Last Post: 18th Sep 2007, 07:20 -
General Guidance and Hardware req. for making VCD with Digital Camera
By dpilot83 in forum Newbie / General discussionsReplies: 4Last Post: 11th Jun 2007, 05:53
