Hello I am having a problem encoding a divx movie, I get an error message when I start encoding that states can't load "p3 package .dll", if anyone can help it is appreciated. I cut the movie with virtualdub.
Cheers, Neesh![]()
We were put on this earth to do good to others, what they do I don't know
i am having the same problem 2 m8 i will keep an eye to see if we can get some help on this
Use Virtualdub to encode from Divx to another codec for avi, say huffyuv (lossless) or Indeo 5 (a bit lossy). Also save the audio from the divx to a separate wav.
In TMPGenc use the video from abouve & the separate audio. Should work.Panasonic DMR-ES45VS, keep those discs a burnin' -
Dudes....
Open a DOS window.
Type 'PATH' & hit enter. Record the Windows or WinNT path. Its usually 'System32' or 'System'
Go to the folder where TMPGenc was installed. Copy the 'p3package.dll' file onto the Windows 'Path'.
Problem solved.
D
Problem With TMPGEnc
By Halibut72 in forum Video ConversionReplies: 2Last Post: 1st Oct 2008, 11:38 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41 -
tmpgenc 2.5 plus problem
By DSLGuy in forum Video ConversionReplies: 1Last Post: 3rd Apr 2008, 14:38 -
TMPGEnc Problem
By djkevyb in forum Newbie / General discussionsReplies: 3Last Post: 27th Sep 2007, 15:46 -
TMPGEnc Problem !!!!!!!!!!!!!
By homantam in forum Newbie / General discussionsReplies: 2Last Post: 10th Sep 2007, 17:56
