Ok, I was thinking of getting the ATI All-In-Wonder 128 Pro but then I saw that to get best performance you need a PIII. I'm looking for something that would work good for a Celeron 933 mhz processor. I'm interested in capturing high quality videos and also outputting them back to VHS tape. Any help?
<font size=-1>[ This Message was edited by: Valentina on 2001-08-02 21:50:35 ]</font>
Guest
I use the base model AIW 128 PCI with a 733mhz celeron. It works well but it does not have all of the features that the Radeon AIW has. I run the radeon 32MB on an Athlon and it rocks. 352x240 with 2.64 megs/sec. Looks great even full screen on my monitor. And 1/2 hour of video will still fit on one CD in the MPG1 unconverted format.
I use the base model AIW 128 PCI with a 733mhz celeron. It works well but it does not have all of the features that the Radeon AIW has. I run the radeon 32MB on an Athlon and it rocks. </BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
first, what capture features (not gaming) does the AIW 128 lack, and more importantly, why? (if you have a real old AIW 128 PCI 16Mb with the BT829 capture chip that's true, but if you have one of the newer ones with the Rage Theater onboard the capture part of the cards is 100% exactly the same). are you using the right drivers for it? and MMC 7.1? -
patrickm - I agree 100%. Maybe it's the box that each card is installed in. If it was me I'd install the Radeon in my more power box and we both know that an ATI card improves significantly with a more power box. Maybe that's it.
On another topic. I'm almost ready to propose some procedures that have significantly improved my real time MMC 7.1 captures. I'm getting what I would consider close to digital cable capture quality real time. No artifacts and no evidence of macro blocking in dark sceens. My approach is extremely counter intuitive. If I get to the point where I feel like posting my results please give them a try and let me know what you think. The same holds true for stevenh. -
that's certainly true, that performance of the card goes up w/CPU, but it's not as if features 'disappear' if you're not >1GHz
hey, i'd be glad to try it. the only problems mine are having is with "fog at night" type scenes (lethal weapon 4, the scene w/ the boat in the beginning). i have gotten a little better quality by fiddling with the contrast/brightness controls too, but i'll try whatever you have in mind. if you want to private message me and have me 'beta test' it before you post it i'd do that too. -
Hey thank's patrick. The contrast/brightness can work great. Even adjusting the color level can help.
I'm talking about dropping the bottom out of the motion estimation setting and even lowering the search ranges down as low as 1x1 while taking advantage of some of the other strengths of the encoder. Problem is there are numerous variables and finding the sweet spot has been a challenge. I'm finding that as I up the resolution ME settings become less important. High ME levels with high resolutions become overkill and actually degrade the results. They actually tax the encoder unnecessarily. I'm close to the sweet spot but not quite there yet.
It requires a bit of manuvering.
I just did 12 minutes of the Perfect Storm off of digital cable and burned it. Played my burn while the remainder of the movie was on. I've got an a/v switch and switched between my burn and the actual movie. Very little difference. Like none actually.
Close but not quite there yet.
edit here -
I think I used the word "taxed" incorrectly above. I don't know if you've noticed it but if you drop the ME setting down to zero you'll actually start dropping frames.
<font size=-1>[ This Message was edited by: next on 2001-08-03 20:20:37 ]</font> -
On 2001-08-03 12:02:27, Haas wrote:
The best thing for a celron is a Hammer
Hmmm someone has an attitude...........
My 600 celeron ticks along quite well at 903Mz (37 degrees idle/ 45 degrees after a long encode)
Not to bad for a cheap piece of silicon
Capture card for Laserdisc and VHS - Good card/quality
By darkbluesky in forum Capturing and VCRReplies: 85Last Post: 21st Mar 2012, 13:27 -
Connecting TV Tuner Card / Sound card for best audio capture??
By pukhog3 in forum AudioReplies: 9Last Post: 14th Aug 2009, 17:13 -
Capture card or Video card w/ capture tool
By joelson in forum Newbie / General discussionsReplies: 1Last Post: 11th May 2009, 11:45 -
Quality of a DVB/Tuner card ; but simplicity of a Capture card.
By BATGAL in forum Capturing and VCRReplies: 3Last Post: 1st Oct 2007, 11:51 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 6th May 2007, 18:15
