I have a movie that I am trying to burn to SVCD converted to mpeg and cut into three parts. My player can play xvcd and xsvcd as well as all other normal formats. I tried checking off the create a standard complainant SVCD (which would make it a XSVCD) in Nero but my DVD player (an APEX-1500AD) goes crazy when trying to read it. I think its because of the abnormal resolution. The screen flickers and its all distorted.
Then I try allowing Nero to Convert it to a normal NTSC SVCD. Well it works... but it converts it to 480x480 which stretches it out major time. If I do it in PAL (480x5XX) it looks exactly the same. Then I tried burning the MPEG right on the root of the CD which my APEX can read. Well the APEX obviously can't judge it quite right because its very slim and squished and shoved in the very top of the screen with black filling 3/4 of the screen on the bottom.
I know it is possible because with proffesional SVCD releases like Centropy's Spiderman SVCD it has a 16:9 resolution. So how do I do it?
Anyhelp would be welcome
-Thanks in Advance
I think when you re-encoded it you must've used the wrong source aspect ratio.
You could try encoding it to 1:1 source aspect ratio, that should work well. I'd do a smal clip using the source range filters, burn it and agive it a look. The best source to look at as a guide is look at the DivX to VCD guide to see the filter,s etc, and a 1:1 setup.~~~Spidey~~~
"Gonna find my time in Heaven, cause I did my time in Hell........I wasn't looking too good, but I was feeling real well......" - The Man - Keef Riffards
Incorrect Timing on DVD burn: H.264 mp4->ffmpegx->Toast or Burn
By DirectorSG in forum MacReplies: 2Last Post: 29th Jan 2012, 12:42 -
DVDs burn fine, but Audio CDs only burn 1st half of songs right...
By Xenogear900 in forum Authoring (VCD/SVCD)Replies: 7Last Post: 28th Jan 2010, 04:26 -
n00b saving in Ulead for svcds and dvds myspace
By dsound in forum Newbie / General discussionsReplies: 7Last Post: 13th Jan 2008, 12:40 -
2.5.3300 SVCDs getting recoded
By nawo69 in forum SVCD2DVD & VOB2MPGReplies: 12Last Post: 15th Oct 2007, 21:44 -
Winavi v8 SVCDs jerking with SVCD2DVD
By nawo69 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 13th Jun 2007, 16:02
