  1. For some odd reason I cannot remember but there is a software that I know that can convert cue/bin file to mpeg format. Does anyone know of any other programs like that????
  2. its called VCDGEAR, you can get it on the left under CONVERT. :P
  3. its called VCDGEAR and you can get it on the left under HOW TO\CONVERT :P
  4. VCDXRIP (one of the proggies in the VCDImager package) is better as it will not only extract just the sequences but also all the segment-items as well as create an XML descriptor of the VCD.
    You can use VCDEasy as a GUI to VCDXRIP if you don't like working with command console tools.
    Regards.
    Michael Tam
    w: Morsels of Evidence
  5. Is it possible for one to extract a bin to mpg2? Cos I tried to burn the bin to SVCD, but it cant play after overburning on my computer. What am i supposed to do?
    May 2002
    Rainy City, England
    Isobuster will also extract mpg from any disc image. Use *extract but filter only M2F2 mpeg frames*.
  7. Or use VCDXRIP as described before...
    Regards.
    Michael Tam
