  1. i got 2 rips on my hard drive and they need to be split into 2 halves ,but unless i start the cut at 00.00.00 to whatever it wont extract so when when i try to cut the second half it just sits there saying seeking roadtrip.mpg(1/1) and dosent do anthing
    So basically unless u start from the beginig it wont cut it ,y not i need to cut the seoncd half of the movie
    please help
    Mar 2002
    chicago
    please help
    when it says "seeking roadtrip.mpg(1/1)" it's doing just that...it's seeking for the start point of the cut you're making. give it some time, and it will start to "do something" eventually. If you think it's frozen, do ctrl/shift/esc
    and see if it is "not responding"
    what are you askin' me for...
    I'm an idiot!
