I have installed Uleads Video Studio 4.0 and I am trying to capture from my DV-cam using a Dazzle DM-6100 PCMCIA card. The monitor shows the video perfect until I start capturing, then it gets very choppy and 30-50% of all frames are dropped. Have checked that DMA is enabled on HD, have defragmented HD with 10GB free space, have closed all other programs incl. antivirus etc. What else can I do to get this working, i.e. drop less frames???
Henrik Andersson
Make sure that the enable dma gets loged in by hitting ok on the hd window. Also it may be a problem with your firewire card. Check that if it is a TI compliant driver you may need to update the driver to OHCI compliant driver. I did these two things and my dropped frame problem dissapeared.
Device Manager says that the disk is working in Ultra DMA mode and I have tried changing to OHCI compliant driver but I still have the same problem!
Henrik Andersson -
Mystery solved: I was saving the captured clips on a compressed HD. When the disk was decompressed everything worked just fine!
Henrik Andersson
Analog capture with Studio Pinnacle 15HD, Dropped frames?
By rivrbyte in forum Capturing and VCRReplies: 2Last Post: 31st Dec 2011, 16:00 -
Virtualdub VCR capture no dropped frames but 5400 inserted frames in 1 hour
By suloku in forum Capturing and VCRReplies: 12Last Post: 17th Aug 2011, 23:33 -
Pleas Help with intensity pro capture dropped frames issue
By jub2k3 in forum Capturing and VCRReplies: 14Last Post: 18th Jun 2010, 13:38 -
Pryo DV capture adds tons of blank frames in between dropped ones.
By Knightmessenger in forum Capturing and VCRReplies: 11Last Post: 18th Jul 2009, 17:08 -
Jumpy playback, dropped frames during capture, CPU pegged to 100%
By tylerz in forum Newbie / General discussionsReplies: 7Last Post: 24th Jul 2007, 18:09
