Results 1 to 10 of 10
  1. I've been capping and encoding under linux for a few months now. I've written a few basic scripts that I use a lot. Hope these help someone out!
    Each script takes two arguments, the file to be processed and the output filename. You will need transcode and mjpegtools.
    divx2mpg -- convert divx file to vcd
    http://members.cox.net/d.maddock1/video/divx2mpg
    createstill -- convert a png image to a vcd still
    http://members.cox.net/d.maddock1/video/createstill
    vcdencode -- encode a vcd from an mjpeg source avi
    http://members.cox.net/d.maddock1/video/vcdencode
    If anyone improves on these (or has a better one), let me know.
    Enjoy.
    Dave.
    Feb 2001
    51`N 5'W #linux & #vcdhelp @ DALnet
    That's what I like to see.
    Feb 2001
    Berlin, Germany
    Thanks a lot d.maddock1.
    Can you recommend a video editor for linux? Similar to Avisynth?
    Feb 2001
    Truman, what tools do you use?
  5. I haven't seen any front-end graphical programs a la avisynth, virtualdub, or tmpgenc for linux, but transcode can do a lot of the same things. Several avisynth and virtualdub filters have been ported to transcode, it includes bbmpeg code, and uses avifile so it can use win32 codecs like Huffyuv. The downside is it is command-line and there are a million different options.
    This is okay for encoding and really simple editing like cutting an avi (avisplit/avimerge). It has sharpen, deinterlace, etc. filters. That's about as close as it gets. There are a few other basic editing tools I've heard of:
    glav -- (part of mjpegtools) basic cut, merge features.
    kino -- DV editing.
    transcode:
    http://www.theorie.physik.uni-goettingen.de/~ostreich/transcode/
    Dave.
  6. Originally Posted by d.maddock1
    And a few more from me
    One more is avidemux
    http://fixounet.free.fr/avidemux/
    though I have to admit I've not done much more with it than install and open up a few video files. It seems to be progressing quite quickly though.
    VirtualDub also works fine for editing using wine, though I know using wine dosn't compleatly count.
    I've been meaning to write a non dvd centric frontend for transcode or mencoder for awhile now, but I never seem to be able to find the time.
    May 2002
    Vancouver, Canada
    Hello.
    You may want to also take a look at Linux Video Studio, which uses the mjpegtools (as does the aforementioned glav). Seeing how you'd have to install the mjpegtools to make use of d.maddock1's scripts anyway, I don;t think that would be much of a problem.
    The mjpegtools, and I believe Linux Video Studio, can be found at <http://www.sourceforge.net>
    HTH.
    Alan
    Feb 2001
    Berlin, Germany
    Thanks a lot guys. As a real linux newbie I still have to read many tutorials. Thanks for the recommendations, I am going to start after the World Cup.
    May 2002
    Vancouver, Canada
    Just to correct myself, the mjpeg-tools can be found at the above URL, but Linux Video Studio can be found at:
    http://ronald.bitfreak.net/
    Sory if this may have confused anyone.
    Alan
    Feb 2001
    There is a new GUI video editor called Cinelerra: http://heroinewarrior.com/cinelerra.php3.
    It is still in Beta code though.
