Results 1 to 15 of 15
  1. hi
    im after a dvd player with a macro hack that plays vcd/svcd/mp3/rw etc
    i cannot get hold of the dansai tesco are not stockin it any more
    have tried the schneider 856 from asda no macro hack that seems ok had a few problems on certain vcds (craps out and has to be reset so i took it back)
    so any ideas? any info much appreciated
    thx
  2. Tesco Are now selling the New Dansai 952....... (Brought one Yesterday) It looks suspicously simlar to the Pioneer DV444s.... (No Realy!!) - Very slim in silver! - I have'nt tried the original Dansai 852's region / macro hack on it yet..... I'll give it ago later.
    £99.49p - Tesco Store At Bedford !
  3. i bought mine from the co op,110 quid plays everything and theres a hack for it to make it region free,its a naiko 2001b worth the cash
  4. Member MaDmiZe's Avatar
    May 2002
    City of...Atlanta
    In the states I recommend the APEX 1500.. think there may be a newer model of this as the 1500's are harder to find.....
    But sold at places here like walmart or circuit city for under $100. (I paid around $55.00 but that was one of those 7am sale things)
    Mine plays DVD,VCD,SVCD,CD,CDR, CDRW, MP3 and can be firmware updated to Macro and Region free. I think that it would play a piece of bread if it had data on it.
    May 2002
    Rainy City, England
    Best all-round player now that ASDA's Pacific-750 has been emasculated is the Cyberhome 528. Plays everything, but no macro hack as it stands. You need a macrobuster cable to go with it.
    http://www.playstationmods.com/dvd.htm Aso available at Richers Sounds, but currently out of stock, I believe.
  6. Member marvel2020's Avatar
    Mar 2001
    Vorlon Home World
    Man i would recommend you buy a MICO it plays everything even those 99min cdrs'.
    Can't remember the URL though to the site that was selling it.
    Sep 2001
    Japan
    with the latest firnware, the MV on the ADL 528 can be (temporarely) disabled.Was reported at the cyberhome-help forum.
  8. nintip
    Guest
    sainsburys sell one called a meco or look for an xwave but if you want to record to vcr make sure it outputs at pal 50 or you will have trouble with some vcd's trust me i know
    May 2002
    Rainy City, England
    Whereabouts is the forum?
    london england
    pacific code for the 750 Hi i got this from my forum i goto hope this is ok and hope it works for all u pacific 750 owners also code was given by PACIFIC DVD-750 ASDA £90
    And here is the Region & Macrovision Free Code's
    1. Open drawer.
    2. Press 9, 8, 1, 7 on the remote control.
    3. Press ENTER till All, for region free, or regions 1 to 6.
    4. Press RETURN.
    5. To remove Macrovison Press 4,5,6,1, Enter, Return,
    Then Power Off.
    ph@ntom
    May 2002
    Rainy City, England
    NO,NO,NO! This used to work. About a month ago the Pacific 750s had the ability to disable Macro removed. Now the ability to play VCD has also been removed. ASDA has a sign next to the players to the effect that the Pacific does not play VCDs. Although the manual says it plays VCD, stickers have now been placed on the front of the manual saying that it does not. It is not a good buy anymore! 8)
    Sep 2001
    Japan
    Here you are:
    http://forum.cyberhome-help.de/
    london england
    Hi i just brought the pacific 750 and it still plays vcd and used code to make region free but macro not working ;( so any new code or even if i have to put a chip to kill macro i would be happy for ur help
    May 2002
    Rainy City, England
    Thanks Dragonsf.
    AFAIK there is no macro hack for the later versions of the Pacific. Just count yourself lucky you don't have one of the present range, which have VCD playing disabled. 8)
    Best bet to defeat macro is to get a special macro-busting scart cable. Otherwise you invalidate your 3-year ASDA guarantee. Innovations do one, as does Playstationmods http://www.playstationmods.com/dvd.htm Maplin might also have them. They cost between £20 and £30.
    london england
    Thanks alot thinking about it getting cable unit also makes it portable if one of me mates want to borrow it seems to make sense cheers
