  1. Is there a way to open a mpeg file, made with the WinTV PVR PCI, in VirtualDub ? I think I read somewhere that the WinTV PVR makes mpeg files in a somewhat different format. However, although I am trying to learn as much as possible, it is all still very confusing for me.Anyway I cannot open these files in VirtualDub. What should I do, or is it impossible to use VitualDub with these files ?
    TIA
  2. well I can..
    only difference between a mpeg1/2 captured by wintv PVR
    and a standard one is that its not muxed as a vcd/svcd/dvd.
    You have to mux it to have nero accept it etc
    try that before you use vdub
    Gainesville, FL
    vdub does not do mpeg2.
    try encoding in mpeg1, and you will have success.
    cheers,
    kyle
