Ive got the ATI AIW video card in my PC, and I also have the Pinnacle Bungee DVD hooked up as well.
Since I've had both hooked up, the computer has been a little slower, and occasionally locks up. WinDVD won't work, the Pinnacle file player locks up, ect. . . I went and upped the memory from 256MB to 640MB, and that helped a little, but I believe that having both the ATI software and the Pinnacle software may be causing these conflicts with the system.
Any opinions?
Peace,
Allan
You could create a dual boot situationi if you're using a Multi-Boot friendly OS such as Windows 2000 and Windows XP, but if you're using an OS such as Win 98 or Me then you're out of luck.
Creating a dual boot would let you choose which OS would access what capture device.
For Example: [Windows ME & Windows XP dual boot setup]
-Windows ME would have the AIW software and you would use Windows ME with only ATI's software, don't install Pinnacle Bungee cap software
-Windows XP would have the ATI drivers installed but NOT the software, Pinnacle Bungee would be the only capture app used on this parition
IMHO
Reliable USB capture devices?
By slats7 in forum Capturing and VCRReplies: 21Last Post: 11th Mar 2012, 20:32 -
Anyone have experience with these capture devices?
By Supreme2k in forum Capturing and VCRReplies: 2Last Post: 18th May 2010, 09:58 -
USB capture devices vs USB tuner devices...... which are better for recording?
By True Colors in forum Video Streaming DownloadingReplies: 1Last Post: 31st Jan 2010, 16:04 -
This is a tough one! Codec issues - my devices aren't playing friendly
By Kevo123 in forum DVD RippingReplies: 1Last Post: 25th Mar 2009, 16:53 -
DivX and MPEG2 capture devices
By Arcturus in forum Capturing and VCRReplies: 18Last Post: 25th Aug 2007, 00:49
